Bend table in drawing
HakroHakro Member Posts: 67 ✭✭✭
How can I insert the bend table of a sheet metal part (associative) into the drawing?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,025 PRO
    I'm not sure what you mean by bend table, do you mean a flat pattern?
  • HakroHakro Member Posts: 67 ✭✭✭
    Hi John,
    no, I know how to insert the flat pattern into the drawing.
    I want to insert the bend table of the flat pattern associative into the drawing (see attachement).
    There is currently no way to do that, You may need to create an improvement request.
  • trevor_foster217trevor_foster217 Member Posts: 6
    All the bend information is available on the flat pattern but can be a little confusing at times
