Creating a U-Shaped Cavity with Rounded Base in Onshape
fernando_davilafernando_davila Member Posts: 11
Hello Onshape Community,
I'm working on designing a rectangular solid with dimensions 10 inches (length) x 5 inches (width) x 5 inches (height). My goal is to create a U-shaped cavity within this solid, ensuring a uniform wall thickness of 0.5 inches. Specifically, I want the bottom of this cavity to have a smooth, rounded transition between the vertical walls and the base.
I've explored various approaches in Onshape but haven't been able to achieve the desired result. Could anyone provide guidance or recommend specific tools or features within Onshape that would allow me to model this U-shaped cavity with a rounded bottom effectively?
Thank you in advance for your assistance!
  • jelte_steur814jelte_steur814 Member Posts: 489 PRO
    sketch the rectangle, extrude
    sketch the desired u shape, extrude (remove) with a start offset and an up to face with a certain offset.
    to make the uniform wall thickness parametric and easy to adapt, make a variable (#T = 0.5") before the U shape sketch and refer to that in your dimensions and offsets.
    another approach would be to create the rectangle, shell it, and add the center solid part of the u back. then add some fillets
  • glen_dewsburyglen_dewsbury Member Posts: 1,056 PRO
    This can be done wit a sweep as another option.
    https://cad.onshape.com/documents/2e9ab31421e4cce8455c3c86/w/65e81d8a9a40060d6f87efb7/e/aaac91f93479ba49d95e10ac
  • eldon_browneldon_brown Member Posts: 50 ✭✭
    edited April 1
    My Try, with Shell and Fillets:
    https://cad.onshape.com/documents/78d5f27b8957a7986efd4427/w/39b0b6c49783d17f65745318/e/0b6f0b607ae111a4e25749d8?renderMode=0&uiState=67ec161b0261ca7363110645
    —Eldonb
