Validating if threaded parts fits correctly when printed
chandrashekar_rchandrashekar_r Member Posts: 46
I have made a lid with thread (Part Studio 2) for base in Part Studio 1. I am not sure if I 3d print, I will be able to thread the lid to base correctly. can anyone help validate this in design
https://cad.onshape.com/documents/a0ed0118b2296a758c043b1d/w/9c08df2a4a5aec034aa3bc8f/e/b6244c7f30ac3fbd6c064adb?renderMode=0&uiState=67f293e6299ce420296399ca
  • MDesignMDesign Member Posts: 743 ✭✭✭
    your parts are two different diameters so they will not thread together. You can use an assembly to see this
  • robert_scott_jr_robert_scott_jr_ Member Posts: 569 ✭✭✭
    Whoa! That's a lot of threads! Even if they did fit each other, there's going to be a lot of friction due to the amount of surface contact; especially plastic to plastic. I would try for way fewer, more robust threads. I would guess that the threads you have modeled are much too fine to hold up to an even minor cross threading.
    Printing this on a filament printer, I would not expect the outcome would be anything useful. A resin printer could probably pull it off but you would still be left with the problems noted above.
    Once you have the male part modeled, you can use a Boolean Remove to ensure you have matching threads on the female part. The Move Face tool can then create a wee bit of wiggle room to allow the threaded parts to screw together easier.
    One last thing: rather than using threads with sharp edges, using a rounded shape would probably do well. Take a look at the threads on a liquid laundry soap container for example. - Scotty
    Don't underestimate what you can do with FDM printers. This was a very functional fine thread. 13/16-20. was just a prototype and never made it to the finest setting .
  • chandrashekar_rchandrashekar_r Member Posts: 46
    Not satisfied with responses
    Not sure what's to be dissatisfied about. you asked for validation but it can't be validated if they don't fit.
