Reset front/ISO view in the model
Is there a way to reset the front and/or ISO view for the model? Inventor has this feature
  • NeilCooke
    NeilCooke Moderator, Onshape Employees Posts: 6,121 image
    Model direction on screen should not matter, but you can use Named Views
  • david_salonia
    david_salonia Member Posts: 4 EDU
    OK thanks.
  • will_fredin
    will_fredin Member Posts: 7 ✭
    I have had a challenge with kids making good front views in their drawings and hoping to do this as well.
    So here is how I have gotten around this for kids who are putting in poor front views into their drawing.
    On the part studio tab place the object in the front position facing you as desired.
    Below the navigation cube where is the dropdown for iso, dim,.... you can click on name view. Give this a title such as "True Front"
    Then when you go to place your view into a drawing KIds can select this view. It is below the insert view in the "View orientation" dropdown menu.
    Hope this helps.
  • matthew_stacy
    matthew_stacy Member Posts: 489 PRO
    @david_salonia try the <Shift><7> keyboard shortcut to quickly return to the isometric view.
  • rod_muirhead943
    rod_muirhead943 Member Posts: 96 EDU
    Mr. Cooke,
    Model direction is a major issue and very important. There should not have to be get arounds, work arounds.  Inventor allows this and this is Very Important.  Onshape needs to add this programming feature asap!
  • rod_muirhead943
    Onshape also need to mimic actual real materials selection like Inventor along with the master data base of fasteners like Inventor.  If OS is looking to be world class #1, then many, many pinnacle features from other systems need to be implemented!
  • NeilCooke
    Mr. Cooke,
    Can you please explain why it is a major issue? Onshape (or any other CAD for that matter) does not care. Even for 3D printing you can reorient the model in the slicer. Create or vote on an improvement request - if enough people vote then we may consider it, but it would be really low priority in the grand scheme of things.
  • tom_hannon
    tom_hannon Member Posts: 4 EDU
    If you click the isometric view button to return to that default view, you can then use the transform tool to position the part as you like and it will take on those views.
  • GWS50
    GWS50 Member Posts: 535 PRO
    Named views are very useful and give you a great deal of versatility
  • Contract_CAD_3
    Contract_CAD_3 Member Posts: 2 PRO
    Named views are great for returning to a non standard view.
    Named views are a poor workaround for a model with non standard orientation. It happens, and sometimes it's not practical to reorientate the model. Named views kick the user out of a command when selected.
    It would be far more helpful to be able to manually orientate the model to (for example) where I'd like the 'Front' view to be then reorientate the standard views so that becomes the new Front. It wouldn't change the orientation of planes or anything else in the model.
    S1mon Member Posts: 4,613 PRO
    Transform.
  • aeromorrison
    aeromorrison Member Posts: 92 PRO
    This isn't only a Part Studio issue. It's also an issue in assemblies. Clicking the corners of the view cube doesn't actually produce an isometric view—it seems to be a trimetric view and always has Z pointing upward. Assemblies may not always have easy-to-access view normal planes for reorienting in order to save a Named View. Transform isn't available in the assembly view. So, if company or industry standards requirements don't align with the Front/Right/Top ISO view default in Onshape (true in my case for almost every project), then it actually gets quite tricky to get assemblies and related drawings precisely oriented without quite a bit of extra work.
    The Named Views would be satisfactory if there was a way to precisely orient the assembly prior to saving the Named View.
  • sage_kim535
    sage_kim535 Member Posts: 2 ✭
    While I don't think this is a major issue, it is an issue nevertheless. I used to teach both CAD course and a course in computer integrated manufacturing.
    Depending on the method of production, model orientation is different. For example, FMD 3D printing and similar will prefer orientation that minimizes or eliminates overhangs and maximizing area of the base (for optimal bed adhesion), while milling may require the model orientation to be completely different. I used to use inventor to teach both courses and in the case of inventor the student simply changes model orientation so that when the .stl is imported to the production control software (ex. slicing program), the model is already oriented in the optimal direction.
    For the hobbiest, the person drawing the file is usually the person manufacturing it, and in these cases orientation in CAD is not so important because the person can simply change orientation within the slicing software to match the fabrication process.
    But whe way I ran my class, the students would export to .stl and leave it in a shared folder, and each student would take a turn placing the .stl's on the beds of slicer and setting print.
    Of course one can get by this by having the designer create a note for the model, in which they can specify the side that should be facing the printbed (or facing up for 3D milling or which side for rotary mills), but for simple 3D printing, importing the object into the slicer and have it land already oriented optimally for the 3D printing can eliminate some hassels.
    If you look at some objects in repositories such as thingiverse, some descriptions will say things such as, "just drop into slicer, and leave orientation alone" or, "make sure that {insert feature here} is facing the printbed".
    After i left the intro CAD class, and a different instructor took it over, he barely covers basic CAD, let alone any advanced techniques. the 3D printer room used to be filled with printers making spaghetti because a student would just drop another student's STL, and hit print, because sometimes that's what teenagers do.
    In the broader scope, I would think adding this feature makes sense (I am not an engineer, a molecular biologist and biochemist by training) because sometimes an engineering designer would make the prototype and then send it off site for fabrication. I can see why someone would want the layer lines to be oriented certain direction in relation to the part because a 3D printer part will have different compressive and shearing forces going parallel or perpendicular to the layer lines.
