Simple cube?
alexander_potochkin
Member Posts: 45 ✭✭
Hello
This must be a very basic stuff - but I can't figure out how to make a cube in a right way.
So I did the following:
1) Made a square
2) Extruded it
3) And here I stuck, since I wanted it to be extruded to the exact length of the base square's side,
so I could change its length and have my cube size properly recalculated.
Could you point out to the right tutorial/webinar/whatever please?
Thanks a lot!
2) Extruded it
Thanks a lot!
OK, only TWO to go!
to others : sorry , private jest
