How do I edit an object imported as an STL file?
frank_paynterfrank_paynter Member Posts: 32
servo_mount_disc (1).stl | servo_mount_disc (1)
I have an STL model I imported, and I want to remove the flange, leaving only the cylinder with interior teeth. I tried adding a cylinder and using the Boolean function, but that doesn't seem to work. Can anyone tell me what I'm doing wrong?
