Sketch constraints
göte_berggren
Member Posts: 5 ✭✭
in General
In the Sketch dialog, checking the box of "Show constraints" does not work.
If it is replaced by the "Constraint manager" it should be removed for selection.
Works fine for me. If there aren't any constraints, it will show nothing.
Can you share a document?
Yep, I confirm there is an issue. It does not show constaints in all situations. I check the box and constraints show up, but only for a short period of time, then they vanish one by one, until I uncheck the box and check it again.
Sounds like something to send to support. I wonder if it's browser specific?
