Error with extrude on point selection
 Matthew_Rosete380
                    Member Posts: 48 ✭
Matthew_Rosete380
                    Member Posts: 48 ✭
            So I just started feature script and was going through the lessons, however when I tried to do create a extrude on a sketch that I made on a point it failed
However when I remove the extrude I can see the sketch so why doesn't this work?
Here is the doc https://cad.onshape.com/documents/b2796104b9b0304547a8abee/w/fdfe0d0c32d8a9d9c0db7fc5/e/dc41644a1289cee5a798bf87
             Matthew_Rosete380
                            Member Posts: 48 ✭ Matthew_Rosete380
                            Member Posts: 48 ✭Never mind, I figured it out You need to multiply the normal in the plane 0
I dont know how to use feature script, sorry :(
