Sequential Extrude Thin Multiple FeatureScript?
sasha_sklar061
Member Posts: 14 ✭
Is there an existing FeatureScript that would allow you to input a list or sequence of sketch profiles to extrude thin in a single feature?
I use onshape for creating 3d printable objects, many of which are decorative or contain decorative elements. I know onshape is probably not the best tool for the job here but I love it and don't want to switch to something else. I use "extrude thin" a lot but it's often cumbersome because of the limitation with intersecting lines and curves. I understand the reason for the limitation, that the operations are modifying the target object, but could that be solved by having a feature that applies the extrusions in a sequence?
eric_pesty
Member, pcbaevp Posts: 2,469 PRO
I would try the "rib network" FS, it might work for you depending on what you are trying to achieve…
https://cad.onshape.com/documents/67de1cda4399707a3649fcdf/v/26c4d9efa4f624f567914d8b/e/80d20fa444414687e1e7b2fd1
Thanks, I'll give it a shot!
