how complex a shape can the software Handle?
joshua_sams
Member Posts: 29 PRO
I'm trying out some files from a 3d scanner
there are quite a few triangles in the mesh. about 1.4M
when I move the item around I get a perfectly acceptable frame rate and the computer indicates about 30 per cent GPU load (RTX2070 Super)
but that's only after it starts moving. when I first move it I get a total freeze for around a second.
similarly zooming in to the item results in a delay of around 1-4 seconds before anything happens.
it seems like my PC can handle it but Onshape can't?
iv tried on my laptop too and that works just the same. slightly slower frame rate as its a lower spec card but its perfectly useable once it gets moving
https://cad.onshape.com/documents/4a6640a8c4ce29b9853e81cf/w/938222efed93405b99c60b8a/e/dd0e2494fb30da5dfbfdbc37?renderMode=0&uiState=65ce4b647f16bb450ff35481
Click on the Camera and render options drop down over on the right of your screen and change it to Shaded without edges. This should get rid of the lag unless you drag your cursor over all the vertices which will slow it back down, so try avoiding bringing your cursor over the part until you are ready to click something.
This is currently one of the limitations of Onshape's mixed modeling.
Legit scans btw, which device did you use for the scanning?
RENDERCAD
that makes sense, thank you.
do you know anywhere that has a good tutorial on mixed modeling in onshape.? I'm struggling with it a lot
the scan is from a MOLE scanner. its quite a cheep unit around £550 but i didn't take it myself. i just downloaded it.
I'm trying to work out what our workflow would be when using a 3d scanner to see if its useful before i commit to buying it.
so far it seems useful but won't be very useful unless i can get better at mixed modeling!
My recommendation would be to create a new model based off of the scan without referencing it directly with constraints, then suppress the import from the feature tree so that it doesn't slow down production.
RENDERCAD
I'm on a MacBook Air with an M2 CPU/GPU and 24GB of ram.
Unfortunately on an nVidia laptop you cannot change which GPU to use for web browsers.
@joshua_sams This is incorrect. On Windows, NVIDIA Control Panel > Desktop > Program Settings > 1. Select a program to customize 2. Select the preferred graphics processor for this program.
You may have to change it from the NVIDIA app if the settings aren't in the NVIDIA control panel:
RENDERCAD
