Can't access public custom features in Onshape education enterprise
john_reed263john_reed263 Member Posts: 11 EDU
I've been using Onshape in the high school class room for the last 5 years and really like it.
Ran into a problem today: Some students with education enterprise accounts aren't able to see public custom features made using feature script. But some students can see it. They are all organized in the same class and I have the classes added to the "Allow Access to Public Documents" section in the settings.
The custom features
we are using are "Laser joint" and "auto layout" that helps in make boxes with box joint joinery. You can see that there is no "public" option and if I search on this with the correct search terms ("laser joint" and "auto layout"), nothing comes up. Here is a video showing someone accessing these custom features:
Learn Onshape: Design A Simple Laser Cut Box in Under 5 Minutes
Any ideas? Thanks
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,864
    It's a global setting that is off by default. You will have to ask your admin to enable it.
  • tim_pinkertontim_pinkerton Member Posts: 4
    I don't have the enterprise education account, but just the "regular" education classroom. I am having the same problem, and don't know where to find the setting to change.
    I am having the same issue of feature scripts I had students use in the past are greyed out. I don't have the enterprise account, but do have a classroom. Does this have the same setting? If so, where do I find it?
    Thanks
  • kate_leipold_ritkate_leipold_rit Member Posts: 43 EDU
    https://cad.onshape.com/documents/578830e4e4b0e65410f9c34e/w/d04a088a0a8ab8361a2aa65c/e/7af109b2f1cead90850525ae - This is the link to the Laser Joint custom feature. Can you open it? Can you make a document to share with students that includes it? Can they click on the feature to open linked document?
    https://cad.onshape.com/documents/576e01dbe4b0cc2e7f46a55d/w/b7cb6876d1121a6c249f59c7/e/b72c231628b5affea0873222
    I always try to make sure the custom feature I'm sharing is the original author and not a duplication.
