Move Drawingviews via arrow key
Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
Is it possible to move drawing views via arrow keys?
Best regards,
Axel Kollmenter
  • leecaseyleecasey Member Posts: 36 PRO
    Would also like to know if this is possible?
  • martin_kopplowmartin_kopplow Member Posts: 987 PRO
    Not that I'm aware of. You can drag them with the mouse pointer though, and they have auto-adjust.
    reason I ask is I'm using onshape (finally) for P&IDs I need to fine adjust valves etc. I'm surprised this isn't possible. I'll feature request it. Thank you.
  • MDesignMDesign Member Posts: 1,128 PRO
    This can apply to more than just drawing views. And if it were available, I would use it a lot. Revit has this functionality and it applies to most any entity you select.
    @leecasey
    Wait, so you're asking to adjust views in a drawing via arrow keys in order to fine adjust valves? I might have misunderstood the whole thing but to me that sounds like a misuse case. In my world the relative position of parts etc. is adjusted in assemblies.
    What exactly is the workflow you intend?
