How to curve this part to the surface?
tom_laheytom_lahey Member Posts: 18 ✭✭
HI,
Trying to use wrap, but cant figure it out… I cant get the diamond patterns to follow the curve. I can extrude the pedal from a side view, and curve it. but I dont know how to transfer the diamond pattern
https://cad.onshape.com/documents/c2a7a858dfb531ae71fa4684/w/c0ebe208e453848b71d1ca01/e/910b3c9a3026d84dd0e6caeb
I also thought there was a fill pattern feature that would allow me to select the space around the edges of the diamond pattern…my work-around is horrible
  • MDesignMDesign Member Posts: 974 ✭✭✭
    You can wrap sketches but not parts. There was a feature script that did some sort of space perimeter for a pattern but sadly I don't remember what it was or what to look for. Maybe someone else can chime in on that.
  • tom_laheytom_lahey Member Posts: 18 ✭✭
    l need some help on this!!
    Perhaps some one could comment?
    I am stuck
  • EvanReeseEvanReese Member, Mentor Posts: 2,478 ✭✭✭✭✭
    Onshape can't bend a part that's already been modeled (yet, I hope!). Your approach should be to model it already bent. Here's a quick example of how I might approach it. Though I'll say your model has a lot of wonky practices that I didn't fix. I recommend digging into Onshape Fundamentals in the Learning Center.
