⚠️How to Simulate Assembly Rail Collisions
MichaelPascoeMichaelPascoe Member Posts: 2,811 PRO
edited April 2025 in General
There's probably a tech tip or post on this, but I thought I would share anyways.
You can simulate collisions on a rail with dynamic limits by:
Linear Rail
  • Have each rail object start at the end of the next rail object.
  • Limit their slider mates to a slide min of 0.
  • Place one parallel (Or another slider?) mate at the end of the last rail object to the end of the rail with a min or max z limit (it depends on the direction of the mates).
https://cad.onshape.com/documents/6994e915ad627194a0adb342/w/3058edd611547121a3d93ba9/e/4e6b764ef825d94c54c5a1ba?r…
Alternatively, instead of a min slider limit where they all reference each other, you could probably have 2 parallel mates per end of a rail object, but this would take more time to set up.
RENDERCAD
  • MichaelPascoeMichaelPascoe Member Posts: 2,811 PRO
    edited April 2025
    Circular Rail
    • Have each rail object start at the end of the next rail object via a rotated mate connector from the original part studio of the bracket.
    • Limit the revolute mate to a min rotation of 0 for each mate.
    • Place an additional revolute mate between the last bracket and the first one, and give it a limit of 360 deg.
    RENDERCAD
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 817 PRO
    What about a straight into a curve? I wanna simulate my garage doors
