Cannot resolve plane in Feature Script extrude
tom_savu433tom_savu433 Member Posts: 7 EDU
Hi,
I am new to Feature Script and I am trying to create one for placing, on a cylindrical part, a groove for a Seeger ring.
I need to remove from the cylinder using an area between two circles.
Before placing the opExtrude function, the script works and the sketch with the two circles is created.
After inserting the opExtrude, I receive the "Cannot resolve plane" error.
Can anyone tell me where I am wrong, please?
Here is the code
FeatureScript 2641;
import(path : "onshape/std/common.fs", version : "2641.0");
annotation { "Feature Type Name" : "Canal_arbore", "Feature Type Description" : "" }
export const Canal_arbore = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "Muchie arbore", "Filter" : EntityType.EDGE, "MaxNumberOfPicks" : 1 }
definition.Muchie_arbore is Query;
    // Get the plane of the selected face
    var Plan_muchie = evPlanarEdge(context, {
            "edge" : definition.Muchie_arbore
    var Muchie = evCurveDefinition(context, {
    var Raza_muchie = Muchie.radius;
    println(Raza_muchie);
    var Raza_int = Raza_muchie - 1 * millimeter;
    // Create a sketch on the selected face
    var sketchId = id + "toolSketch";
    var toolSketch = newSketchOnPlane(context, sketchId, {
        "sketchPlane" : Plan_muchie
    skCircle(toolSketch, "circle1", {
            "center" : vector(0,0) * millimeter,
            "radius" : Raza_muchie
    skCircle(toolSketch, "circle2", {
            "center" : vector(0, 0) * millimeter,
            "radius" : Raza_int
    skSolve(toolSketch);
    opExtrude(context, id + "extrude1", {
            "entities" : qCreatedBy(id + "toolSketch", EntityType.FACE),
            "direction" : evOwnerSketchPlane(context, {"entity" : definition.Muchie_arbore}).normal,
            "endBound" : BoundingType.BLIND,
            "endDepth" : 2 * millimeter,
            "startTranslationalOffset" : 2 * millimeter
    opThicken(context, id + "thicken1", {
            "entities" : qCreatedBy(id + "extrude1", EntityType.BODY),
            "thickness1" : 0.1 * inch,
            "thickness2" : 0.1 * inch
    opDeleteBodies(context, id + "delete1", {
    opBoolean(context, id + "boolean1", {
           "tools" : qCreatedBy(id + "thicken1", EntityType.BODY),
           "targets" : qOwnerBody(definition.Muchie_arbore),
           "operationType" : BooleanOperationType.SUBTRACTION
  • Caden_ArmstrongCaden_Armstrong Member Posts: 298 PRO
    Start with reading the error message:
    "evOwnerSketchPlane: CANNOT_RESOLVE_PLANE"
    If you read the documentation for this function, you'll find that it is expecting a sketch entity.
    Your feature is selecting an edge, which is not a sketch entity.
    You don't even need to find the plane again here, since "Plan_muchie" already exists. Just use Plan_muchie.normal
    Its good practice to read the documentation and see if the function inputs match what you are putting into it.
    www.smartbenchsoftware.com --- fs.place --- Renaissance
  • tom_savu433tom_savu433 Member Posts: 7 EDU
    Sorry Caden, but I don't understand, I'm an absolute beginner in Feature Script.
    I've tried different solutions for the "direction" argument of opExtrude and for the "entity" in evOwnerSketchPlane, but none worked.
    I tried also evPlane instead of evOwnerSketchPlane, no result.
    I've read the documentation, it seems pretty clear, but I really don't know what I'm missing.
    Solved it, thank you!
