strain/displacement in simulation FEA
jelte_steur814jelte_steur814 Member Posts: 507 PRO
edited January 2024 in Simulation
Since most polymers behave non-linearly in the elastic range, and most snap hooks etc are not force limited but geometrically defined. I'd love to see some changes/additions to the simulation.
at the moment i usually apply a force and then trial and error that force till I get the proper displacement of my snap. That sucks and should be easier...
the good thing about applying forces is that it will allow the geometry to move/displace in a natural way, in most FEM software displacement loads lock the rotation of a surface/line/set of point so it won't move naturally. therefore a
However more importantly is that I'm used to looking at te Strain resulting from a displacement so the non-linear elasticity-modulus cancels out. is there a way to get strain results?
kind regards
Jelte
  • chris_gromek_onshapechris_gromek_onshape Member, Onshape Employees Posts: 26
    edited January 2024
    Greetings Jelte,
    Thank you for your suggestions on how we can improve Onshape Simulation.  Luckily, I have some good news: both displacement boundary conditions and expanded results metrics are on our list of near-term enhancements.
    I understand your point regarding locked-vs-free degrees of freedom when applying a displacement constraint, and while I had wondered how many users would appreciate the difference, I am happy to know that at least one certainly will!  Luckily, strain results will be a straightforward addition.
    Regarding the use case you described, non-linear behavior of hyperelastic materials will unfortunately remain out of reach for Onshape Simulation through the near-future.  Though surpassing linear relations and small deformation assumptions is a goal of ours, we will need to make improvements in other areas before tackling those issues.
    Best Regards,
    Chris Gromek
  • martin_kopplowmartin_kopplow Member Posts: 863 PRO
    It's certainly more than one user! I happen to know another one. ;0)
  • HeRoHeRo Member Posts: 4 PRO
    Is there some news on the displacement boundary condition? Otherwise, what are you referring to as 'near-term'? Thanks!
  • Kevin_GallichanKevin_Gallichan Member, pcbaevp Posts: 6
    Hi, I note that applying a displacement is yet to be a thing in Onshape Simulation.
    Does anyone know when that will be available ?
    Thanks
