Expressions - Returning a number when using a length
leecaseyleecasey Member Posts: 36 PRO
Hi I'm having a bit of trouble generating an integer for a pattern number from an expression which is using an length (mm).
floor((#length/2)/60)
I'm assuming the issue is incompatible types but not sure how to solve it. Is there any way to cast #length as an int?
