Exporting threads to stl or 3mf for printing
michael_hiltz909michael_hiltz909 Member Posts: 2 EDU
Hello! I just got into the amazing world of onshape a couple days ago. I am trying to make a holder for a usb microscope. I was hoping to screw the holder into a base. That way, I can use the base for other "holders" in the future. It seems the base part exports with internal threads from onshape to stl. However, I am having trouble exporting the holder which has external threads. When I export the holder in either stl or 3mf format the threads are not visible in the slicer. I am using bambustudios for printing. Ill add the onshape screenshot showing (in green) where the threads are and the bambulabs screenshot, showing now threads.
What an amazing software! Any help would be greatly appreciated. Thanks a million in advance!
  • klaus_krämerklaus_krämer Member Posts: 92 ✭✭✭
    I'd recommend the ThreadCreator Tool. It works quite well, even if it adds threads to inner zylinders instead of carving them out.
    When I use it in sizes from M5 to M8, I use a cylinder diameter of x mm for Mx screws and a diameter of x+0,4mm for threaded holes (inner cylinder). With these I can use either printed screws/nuts or normal industrial screws/nuts in any combination.
    Simply try it out printing them and test with their metal counterparts to find your preferences.
  • tibor_szabo241tibor_szabo241 Member Posts: 2
    Open
    https://cad.onshape.com/documents/6b640a407d78066bd5e41c7a/v/21ef017a4e386179c3be31f3/e/c953720c264ce001f1a82dc1
    then click this button:
    In the now newly opened window click
    That's it. You'll find the Threadcreator tool by this icon:
    Click it, use it and be happy!😉
