Set Property (New Custom Feature!) 🆕
MichaelPascoeMichaelPascoe Member Posts: 2,429 PRO
edited July 2024 in FeatureScript
Set Property allows you to:
  • Dynamically set the properties of your part or multiple parts.
  • Set custom properties.
Tips:
  • Custom property ID's are found in your company settings.
  • Right click on any value input to convert it to expression. This means you can use variables to drive the values.
  • Want more cool custom features? Visit https://www.cadsharp.com/featurescripts/
Do you spend hours everyday in Onshape? Consider automating your process with custom features and API.
CADSharp specializes in custom features and API.
