I am looking for help
I want to put raised text on the outside of a cylinder (coffee cup). I am not real good at CAD but I get by.
  • matthew_rosete380matthew_rosete380 Member Posts: 31
    U want to try to use the Wrap tool to ur advantage like this
    Creat text on the clinder (Most likely will be on a plane)
    Then use the wrap tool to help you like this to add the surface you want
    Here is the doc to see exactly what I did: PS U can use the angle to make it not look upside down
    https://cad.onshape.com/documents/1b494dddb920736c62d4fd03/w/89c0a35a8742f34c4d616285/e/8ba192460fddfeabd8c7ffd4?renderMode=0&uiState=6810f845888bec5ec12049f7
  • colin_king506colin_king506 Member Posts: 42
    Try the too: https://www.youtube.com/playlist?list=PLfl1MlLvzE_o6emduIhP-0IocQWubmW6F
