Surface Text Cut Out
rod_muirheadrod_muirhead Member Posts: 8 EDU
I am unable to Cut Out the surface text. I actually need to cut the test out all the way through. Any help is appreciated..
  • MichaelPascoeMichaelPascoe Member Posts: 2,827 PRO
    Try changing the base surface to the actual surface of the part instead if the sketch face. This should allow the feature to find the correct body.
    RENDERCAD
