Best way to make this organic type shape.
brian_wagener
Member Posts: 28 ✭✭
in Drawings
I want to ask about this because I have used onshape for a while now, but only for mechanical type things and not things with organic type curves such as this. If you were to recreate the grip of this controller, how would you do it? My first thought would be to use loft command and various offset planes. But I think that would get tricky as we get to the ends. Anyone have any techniques for something like this?
If you take the curves and surfaces courses in the Learning Center, you'll end up making parts like these.
In industry, designers usually make organic shapes with curves and surfaces. It's a completely different way to design. Its not easy….
