Modeling Volume with Cross Sections
garun_arustamovgarun_arustamov Member Posts: 4 ✭✭
I'm curious if it's possible to model a 3D shape that uses (ideally) two equations such as sqrt(x) and just the x axis (or x^2), and extrudes upwards (let's say) a square where the base of the square is between the equations. Hopefully that makes sense, but if not, here's a video that explains it much better:
I was able to do it on solidworks using a sweep and with a guide curve but it doesn't look like that option is available in OnShape. I tried using a loft but could not get the exact correct shape.
I was able to make an equation driven curve thanks to a feature script that folks made, but that is as far as I got.
Thanks in advance!
Garun
  • jelte_steur814jelte_steur814 Member Posts: 489 PRO
    if you're able to plot both curves in the graph, you could extrude the area in between.
    all you need is on the x-z plane a third equation which would be given by z=sqrt(x)-x^2.
    extrude all those curves and enclose the space in between:
    https://cad.onshape.com/documents/f47033ca7b6ec754e0f4e2c6/w/e8fe0533d85e6589ca772b0a/e/0d46ba184f2c6a78964e9f33?renderMode=0&uiState=681e0265eb695d2078a99d5a
