Does Onshape have this spline fit feature?
bast_industriesbast_industries Member Posts: 4
hello does onshape have this spline for feature shown in the video below? I have imported a sketch but I want to smooth out all the spline curves to one curve and arcs and circles.
https://youtube.com/shorts/ge2TU6z0X6M?si=YgTZF4dwfLLk2wuA
Best regards,
Bast
  • jelte_steur814jelte_steur814 Member Posts: 459 PRO
    If you only want to combine them into one, without editing anything, use 'Composite curve'.
    if you really want to smooth it out, try 'edit curve'.
  • eric_pestyeric_pesty Member Posts: 2,172 PRO
    The function isn't the sketch but the "edit curve" feature with the "approximate" option can basically do this. Although you will end up with a "curve" entity instead of a sketch
  • EvanReeseEvanReese Member, Mentor Posts: 2,373 ✭✭✭✭✭
    The other suggestions here are good, but the 3D Fit Spline feature with Edges mode is the closest thing to this, though as others say, it won't be sketch curves anymore. You could create all of your fit splines, then make one final sketch and "Use" the new splines to get it all back into one sketch again.
  • bast_industriesbast_industries Member Posts: 4
    Thank you I will try these and see how it works out this week
