Connecting two points on separate planes
grant_harris979grant_harris979 Member Posts: 5
Hello. I need to create the blue line between the two points which are on 2 separate planes. How do I do this? Thank you
  • jelte_steur814jelte_steur814 Member Posts: 498 PRO
    either bridging curve if it's just two point, or routing curve if you would like to add more points in one go.
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 321
    edited May 12
    3D Fit spline would be yet another way. Hint: Preselect the two vertices, then start the 3D Fit spline command. You're already done.
    Also, after you've created the curve (using whichever of the methods above) you can use Edit curve to further refine it, reparameterize, planarize it, move control points, etc.
  • grant_harris979grant_harris979 Member Posts: 5
    I figured it out
