Shell not working - "Could not shell part with selections"
Ethan_Kinney_Ethan_Kinney_ Member Posts: 4 EDU
Shell doesn't work when trying to shell a loft unless the thickness is very small. Also the loft is a bit twisted looking and I'd like for it to be completely straight.
https://cad.onshape.com/documents/b11194e72249eb9699d1bdaf/w/eb35e5f943dcc03c2d6e6e09/e/b74652bda66f725e89594f90?renderMode=0&uiState=6824d57b026f36148c45092f
Above you can see the loft isn't perfectly straight and has a bit of a dip or twist (top left).
