Basket
can anyone help me? I'd like to build this chip tray for a project
  • l_p669l_p669 Member Posts: 11
    Your approach will vary a lot based on your specific needs:
    • How accurately you want to represent it.
      Do you need to model the wire
      Is just the general idea of "walls with tons of squares punched out" enough?
    • Is it being modeled for output/printing?
    If you go through the onshape tutorial "Onshape fundamentals" you should be able to make a simple version of this: https://learn.onshape.com/learning-paths/onshape-fundamentals
  • scott_willis165scott_willis165 Member Posts: 20 ✭✭
    edited May 2025
    Need to know how you are going to build it — what kind of tools and materials are available to you? — and what level of resources are you willing to dedicate to the task?
    • Will you be wrapping support wire and welded mesh around a form, and brazing or spot-welding?
      • Do you have access to a spot welder?
    • 3D printing it (will be very weak, unless e.g. you print the sides flat then join them)?
    • Using individual wires (would take forever)?
    • Thin plywood and a laser cutter?
    The specific product in the picture you attached is in the '$500k..$1M to build a semi-automated production line, then $0.35 each' category.
  • eldon_browneldon_brown Member Posts: 50 ✭✭
    OK, . . . I just had to model it for fun.
    —Eldonb
    https://cad.onshape.com/documents/7e30168f7b26e3335939e859/w/16bfd4d58bb20ab5261bdbec/e/9ba72fe336ad37f71f15c4e0?renderMode=0&uiState=682ad02c84e522147fd39b95
