Dimension line distances
dennis_kaufmanndennis_kaufmann Member Posts: 7
Can I set the distance between body, dimension line and subsequent dimension lines?
I work in the standard DIN 406, and in that the first dimension line has to be 10 mm from the most outer spot from the body, then each following dimension line has to be placed with a distance of 7 mm.
To clarify, I am talking about the distances marked as 19 and 61 in this screenshot:
  • STEGSTEG Member, User Group Leader Posts: 139 PRO
    Dimensions are manually placed. You can submit an improvement request.
