Tricky Frame Corners
george_bankoff664george_bankoff664 Member Posts: 6
Hello. I'm trying to design a car frame, and I'm having some trouble with these two corners.
For this one, I want the edge of the gray piece (the leftmost edge) to be aligned with the edge of the blue piece. Right now, there is a gap because it's drawing the frame from the sketch in the center of the blue pipe.
CleanShot 2025-05-23 at 04.13.59@2x.png CleanShot 2025-05-23 at 04.15.10@2x.png
For this one, since two of the edges require two different angles to trim to the dark blue part, I can't have them in the same frame, but I still need them to connect nicely. I don't care about the angle of the corner—I just want the parts to be flush to the dark blue one.
