Introduction to Part Studios - Exercise: Control Arm
david_zulkiewskidavid_zulkiewski Member Posts: 4
I am working through the exercises ahead of my students and ran into some issues with the Control Arm. I had a hard time adding the constraints and ended up using dimensions to create the correct size part. When I tried to create the coincident circles and center point rectangle one of the circles disappeared. Symmetry also gave me some issues and never appeared to work. I created the part twice and never received the correct surface area of the part. What can I do? I feel some of my students will hit this obstacle and stop working.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 770 PRO
    It might be a good idea for you and your students to take the Introduction to Sketching course first.
    https://learn.onshape.com/learn/course/fundamentals-sketching/
    That would give everyone a solid foundation before tackling the Part Studios course.
    Also, here's a quick gif.
  • david_zulkiewskidavid_zulkiewski Member Posts: 4
    Thanks, we will check the sketching tutorial out. I have several years with different CAD platforms and I know there will be a learning curve. I wanted to see what I might be missing with those small differences with the surface area and volumes.
