Second opTransform not working following same format as previous one
RhettRobinson
Member Posts: 211 ✭✭✭
I am practicing some of my FeatureScript skills and understanding (sadly after having to take a break from FS) by creating a FeatureScript that makes three mate connectors in each of the three axis orientations for a selected mate connector location. I can't seem to figure out why this call line is not working when the opTransform above it does work. I have used this similar opMateConnector to opTransform workflow in the past and haven't had this issue.
.yAxis is not a thing. You have to use yAxis(MC)
Knew it was something simple, thanks for the fast response!
