why is my extrude remove not working
simple extrude of letter M, want to see letter N on side; need to remove 2x triangles; why is it not working; only a small part; not overal. Probably because it ends in several bodies..
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 317
    Have you provided the selection of bodies that will be in the Merge scope for the removal?
    Also, can you share a view only link to the document?
