Troubleshooting procedure for fillet failure (and any other failed feature, for that matter)
Experienced designer coming up to speed on OnShape.
When applying fillets I find that the tool frequently fails for no obvious reason. This seems more common on complex shapes.
In this example, I'm trying to fillet the joint between ribs in a hollow, irregular shape.
The fillet in the left hand cavity works fine. The right one fails, even though it's a mirror image.
The only error I can find is "Fillet 6 did not regenerate properly: Adjoining edge not filleted."
The entire feature highlighted purple. Close examination reveals a gap showing the offending edge highlighted red. There is nothing telling me what is wrong with this edge.
Please understand that I'm looking for a general, step-wise procedure to zero-in and solve this kind of problem, rather than a litany of "things I could try" or workarounds.
Is there a way to get more detail on errors like this? Maybe a log file somewhere?
-Matt
Not really more detail available. just kind of by experience you learn limitations/why things error. in you case it looks like the fillet may be trying to self intersect. It doesn't know how to navigate the extreme edges of the fillet as it makes its way around the inside curves. can use a smaller radius or variable fillet in that area. or some other solution.
We always try to provide error messages that are as helpful as possible, as in the one above "…Adjoining edge not filleted." This one implies that, for one reason or another, the tangency propagation did not grab that edge. Perhaps the geometry is slightly not symmetric or tangent (within geometric tolerances)?
As far as troubleshooting, in this case try adding a selection of the additional "missing" edge…
Beyond that, it will be a lot easier if you provide a link to a model so we can look at it in more detail. As you know, filleting is a complex subject and requires a lot more context than the images above.
I don't think Adjoining edge not filleted implies to the user that it could not "grab" the edge. Its possible that it implies the opposite that the program knows it's there and did indeed grab it to present it to the user as an issue.
I have a experienced some issues recently with mirrored geometry not behaving the same as the "original" side, specifically when working with fillets (and drafts). My guess would be that the software uses the "context" provided by the feature creation before the fillet to figure out how to apply the fillet but that gets lost on the "mirrored" side, or something along these lines but you would think the mirrored geometry would work the same!
A couple tricks for troubleshooting fillets:
> The first step is to try a smaller fillet radius to see what happens
No joy... even very small radii fail.
> Temporarily turn off "tangent propagation"
In fact this is how I ultimately worked around the problem, but it's a workaround; not a solution. If my design required the original style fillet, I'd be stuck.
Thanks!
-Matt
> This one implies that, for one reason or another, the tangency propagation did not grab that edge. ... try adding a selection of the additional "missing" edge…
I did that. That's not the problem. I suspect that @MDesign is correct about this error message .
> ...it will be a lot easier if you provide a link
Remember, I'm not trying to solve _this particular_ problem, but am trying to establish a logical, repeatable process for addressing problems of this nature when they arise. I recommend that such a process be documented for each error message. I found no mention of this error message at the documentation site; is it explained somewhere?
I think this error message, and a few others I've encountered so far are too terse to be useful, and was hoping for some sort of 'additional detail' button or log file that might offer a more deliberate approach.
That said, here is a link to the document in question, in case it offers any insights.
https://cad.onshape.com/documents/c95f8fd78c8a7843566095d1/w/8da3d8424883c1f140ca923b/e/bebb3c8ce38b090a2bd27a00?renderMode=0&uiState=68506988dff4e7507cfa7eb7
If it does help, please explain precisely what steps you took (whether fruitful or not) while investigating.
Thanks!
Small tangent here, lol pun intended. I made a feature Analyze Fillet to help find fail points quickly. It may or may not be of use in your application.
You can find it here:
https://www.cadsharp.com/featurescripts/…
Looks like your "fillet1" causes the shape to not be symmetric in the end.
There's some weird condition after the shell where the edge transitions between tangent and not which causes some weird glitch in the surface:
Curvature analysis can help if you know where to look, very small area on the inside:
But the outside with limits set around your shell thickness (used 9-11mm here) shows how you might have some weird stuff on the inside:
Turn off tangent selection. I did this fillet at a smaller radius and it failed. Then set to 10mm and selected edges individually to get a positive result. Tangent selection tries to select around existing fillet generated by shell operation.
Fillet on edge of fillet doesn't seem to work so good.
https://cad.onshape.com/documents/8d80f7b762a738a822ee8429/w/103359dc296701b8edfe87f9/e/866fe18a04a4283a589b73e3
@eric_pesty
Great sleuthing; thanks for taking the time.
The curvature at the point circled in your 4th image changes due to the variable radii I've defined in fillet1. That is by design; this fillet is generally 20x40, but changes around the narrow part of the fingerboard cutaway. If I change the next point along (the 4th from the top of the list), to 20x40 the problem goes away… but that's an unacceptable compromise.
But it does explain why those two pockets are not perfectly symmetrical.
On a separate note, I can't really tell what part of the model your first three images are referring to.
It looks like you've used a section view on your 2nd image, but I can't reproduce it.
I also can't figure out how you got the view shown in your 3rd image. This seems to be a curvature color map… can you tell me the endpoints you used? is this a 'min radius' view?
And of course, none of the above solves the problem, though it does help characterize it more thoroughly.
Is there some way to precisely locate the discontinuity and "repair" it?
Thanks… I haven't tried it yet.
but, I think I have located the failure point without your tool.
This question is what to do about it?
What to do about it will depend on how picky you are.
Option A
Do you want an EXACT offset / shell of the original face around that fillet area? Then you will have to find a way to fix the curvature because fillets don't like curvature spikes. Shell / Offset / Thicken can often produce curvature spikes which will cause the fillet to fail.
Option B
Place your main fillet after the shell feature, then you can estimate the inside surface either by copying the original face and moving it, or possibly by creating another fillet on the inside.
Here is an example of what option B would look like:
https://cad.onshape.com/documents/d16046ebb9c1baeef21982ff/w/5ae4177e634a7f40f440d43b/e/258793338f224114727…
First images are the inside area opposite the circled area on the outside. What I noticed was that the section that should have been straight was broken up into two segments so I zoomed in and did a section (along the right plane).
The view is min radius with limits set to 9 and 11, i.e. either side of the thickness.
One way to fix it is to delete the offending faces and patch with "fill". In this case it seems to be just the vertical face, just needs a new straight edge at the bottom (using a 3d fit spline) and it works:
@MichaelPascoe
This is really an interesting approach.
For the benefit of those who haven't taken the time to review Michael's document: he's rebuilt the entire set of inner faces using a copy of the outer bottom faces, shifted upward by the thickness of the original shell. Reviewing the operations has been an educational tour through the surface modeling tools, which I hadn't yet explored.
As he says, this estimates the original geometry; it does not precisely reproduce it, since the shell operation's inner faces are not exact copies of the outer. We can see this by observing the model while dragging the rollback bar over the 'repair pocket' folder, or use the measurement tool to check one of the inner vertical walls: original height: 20mm; after the 'repair pocket' operation it's 23.229. This yields a sharper internal edge between the sides and bottom, and a slightly non-uniform thickness in the curved sections.
Thus, strictly speaking, I must consider it another workaround, though a very interesting and thorough one. I would expect this approach to work well even if there were lots of glitches instead of just one.
Thanks for taking the time!
The real culprit here is that offset / thicken , shell, sometimes can't produce a smooth surface. @Jacob_Corder would be able to explain why. He's an expert at the art of b-splines😎
I imagine with the new approximation tools we have now in FeatureScript, we could make an approximate offset surface tool that could be used to fix all kinds of issues like this. This would let you make those offsets without the spike in curvature.
@eric_pesty
You've taken a more surgical approach which zeroes in on the offending edge. It seems to be the uncompromising solution I was asking for, but I've been unable to reproduce it... your nifty screencast perhaps hides some feature parameter that I must be missing.
I wonder if you would mind posting a copy of your document as @MichaelPascoe has done , or maybe just give me more detail on the settings in the features you've added.
Thanks again for all your efforts
@MichaelPascoe
Yes… I experimented with offsetting the bottom by 10mm, but it fails; works at 9mm and below… though the 'shell' operation would seem to do the same thing. Curious.
I meant to do that in the first post!
Here's the doc:
https://cad.onshape.com/documents/98d4a833e63029819ec8ed40/w/f349ecb2d38457485885108d/e/48137957c205efab8d00cbf7
I had originally deleted two faces i.e. on either side of the "weird" line when I created the 3D fit spline I went back later and realized I didn't need to delete that lower face so removed it from the delete feature. I'm guessing if your are trying to replicate there might still be some odd vertex in there that you might be grabbing when trying to create that replacement edge.
Bonus pro tip: you can filter the history with a feature name to see how it evolved (useful when going through someone else's work)!
@matt_keveney Easy fix rather than messing with surfacing edits. change the the shell to 9.95 or 10.05 thick. Doing so eliminates those little segments in the corner and the fillets 5 & 6. work as expected. Why? That's above my pay grade as they say.
even 9.99 or 10.02 work. but not 10 or 10.01
You could also add a point to your variable fillet 1 to keep the fillet from changing just a lil longer and it resolves the issue with just that alone.
@eric_pesty Getting back to this… sorry I was away for a few days.
I've reproduced your solution. I was missing the 'continuity' settings on the fill, not yet being very familiar with the surface-editing tools.
So, thanks again for taking all the time. This answer comes closest to solving the problem as I'd originally requested, though the process of zeroing-in on a glitch like this will, no doubt require practice.
…which is probably why everyone else suggested workarounds instead. Thanks, everyone, for your ideas and attention to my question. Often the workaround is faster and acceptable, but sometimes a more definite, deliberate approach without any compromises is called for.
-Matt
