How to make this belt running in uniform speed?
yip_cmyip_cm Member Posts: 24
Here is my sketch:
https://cad.onshape.com/documents/43673a0da24e0c9e62ab9868/w/88b13813022d44800fb0e523/e/647299b45b36c68eeda355b7
  • martin_kopplowmartin_kopplow Member Posts: 839 PRO
    It probably just maxes out the computer's performance. When the load goes round the corner, it needs to do more math and slows down. I know of no way to actively control the speed in a way that makes it uniform.
  • eric_pestyeric_pesty Member Posts: 2,277 PRO
    The variation in speed comes from the fact your are moving at a steady angular velocity which results in variable "linear" speed as you go around the corners.
    Any reason your "track" (part3) can't be a circle, I think that would help…?
  • yip_cmyip_cm Member Posts: 24
    If the track become a circle, the motion will become like this:
    https://cad.onshape.com/documents/81075b2a8b753e62e5b7f7e5/w/c68e971ae8e6e52744a89696/e/e4e04fd7155666b2165aac39
    Right! That doesn't help…
    I guess you would probably have to use a "cam" shape to convert the steady angular velocity animation to a varying radial velocity and convert that back into a varying angular velocity (using rack-pinion) relations. I do wonder if the "track" shape can be used directly for that but I have a hard time wrapping my head around it without trying it out…
