Undefined sketch seems to not be working
Hank_HamnerHank_Hamner Member Posts: 2
A simple sketch set up using the center point rectangle is showing as undefined. Both sides are have dimensions set as length = 100.0 and height = 60.0. The image attached shows all the constraints. This has been happening on more complex sketches and I can't figure out why. I have re-booted my computer and cleared Chrome but to no avail. I am running Windows 10.
Thanks!
  • glen_dewsburyglen_dewsbury Member Posts: 1,214 PRO
    Looks like you missed the origin at the start of the center point rectangle. As you move the mouse toward the origin a square will appear. If you're in the vicinity of the origin but not close enough it will highlight with out the square.
  • MDesignMDesign Member Posts: 1,259 PRO
    As Glen as pointed out…. Number 1 undefined issues that trip up new users is where is it located. not how big or what angles but where is it located relative to other defined geometry
  • bladecbladec Member Posts: 13
    Looks like you are missing a constraint to the origin.
    Forever requiring approval :(
