Error in closing mechanism
Matthew380
Member Posts: 50 ✭✭
Hello, I have been 3d printing and 3d designing for a while now and for some reason my designs for the hinge make the 3d printed object not look closed on the other corners. Here is a image if you can see it:
What are the measurements that you use for a object to close all around it with a locking mechanism since I am running low on filament.
Here is the document if you need it: https://cad.onshape.com/documents/ac6ff110f86cc22f00729c39/w/2266733c64b25fb6a911ec55/e/d7788221ecd53bd2e681b7cb
maybe this will help you.
