API: Determining if there was a regeneration failure
robert_chiodi
Member Posts: 12 ✭
Hi!
I am working on creating an integration with Onshape via the API. I have looked pretty thoroughly through the API Explorer and tried searching the internet, but I cannot seem to find what call is necessary to determine if a regeneration has failed. In the integration, we manipulate variable studio tables, which can be easy to put into a bad state that is non-realizable.
So the crux of the question is: What is the fastest way in the API to determine if there is a generation issue in a Part Studio or Assembly? Currently, we do not care in which part the issue is or what it is, just a binary success/failure criterion.
Thanks!
In a part studio, you can get the list of features using /partstudios/d/{did}/{wvm}/{wvmid}/e/{eid}/features endpoint and check the
featureStatesin the response. This will give you thefeatureIdand thefeatureStatus.Features with issues will have afeatureStatusof ERROR.Thanks, that does indeed work! If I could make a request, it'd be nice if there was a cheaper (less severely rate-limited and quicker) endpoint to just get the featureStatus along with the feature names associated with the node ids.
