Half of flat pattern view after mirroring a sheet metal
Hi all, newbe here,
Just created a new sheet metal part, wanted to insert a flat pattern to drawing but unfortunately I can see only one half of a part instead of whole. What I did wrong or missed something?
Help will be appreciated.
Marcin
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 650 PRO
    Finish sheet metal means you're done with your part and no future updates will affect the flat pattern. You need to mirror before that. Frankly the only reason I would ever use Finish Sheet Metal is for weld drawings but I stopped doing those in favor of just adding the symbols to the drawing view
