Part alignment using width mate
graham_lock
Member Posts: 265 PRO
Hi,
I'm using the new width mate to centralise a pully in a holder as below:
After having setup the width mate what is the correct way to then align the pulley holes?
Or should I just use a fasten mate with an offset?
Any help appreciated.
Thank you.
eric_pesty
Member, pcbaevp Posts: 2,529 PRO
A cylindrical mate should do it (or a slider if you don't want it to spin).
MDesign
Member Posts: 1,286 PRO
In case you wanted to go for efficiency…A single revolute mate would apply well in this situation. no need for both a width and cylindrical mates.
Thanks Eric, the cylindrical mate works well.
Thank you - yes that also works well.
