Approximate Face (New Custom Feature!) 🆕
MichaelPascoeMichaelPascoe Member Posts: 2,497 PRO
edited July 16 in FeatureScript
CadsharpSpin.gif  CADSharp has sponsored a new custom feature:
ApproximateFace.png Approximate Face
This feature uses Onshape's new constrained surface functionality to re-create an approximation of multiple faces. Useful when working with features like Texture or Attractor Pattern that only allow one input face.
CADSharp Feature Library
⚠️ Need custom apps, tools, or workflows? Reach out to CADSharp, we do this for a living.
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 185 PRO
    I saw this pop up on the CADSharp page before you posted this and was like "since when did they have this?"
    Gonna be doing some noodling and seeing if this can help me along with Edit Surface and later my Flex feature.
  • EvanReeseEvanReese Member, Mentor Posts: 2,516 PRO
    Niiice! Will give it a go.
    edited July 16
    Ahh I see, you slap the faces with a bunch of UV points for the constraining operation. I opted not to do that for my edit surface feature because control point or knot density can vary across the surface and I'm trying to aim for locality to be maintained for later when I make tween surface happen. I wonder if this could be modified to extract knots and use those for the constrain instead.
  • MichaelPascoeMichaelPascoe Member Posts: 2,497 PRO
    edited July 16
    Ty!
    It's similar to @EvanReese's drape surface, except instead of raycasting to the entity, it grabs the uv points from the selected faces.
    edited July 16
    Yes I love the simplicity of it! Faster to use, and compute too, I'm sure (though I've not tested). I'll probably reach for it first over Drape Surface and see if it gives me a uv grid I like. If not, I'll use Drape Surface, which is more work, but more control.
    Status update on surface constraining knots directly: not that simple. Knots are sometimes way out in hammerspace for certain surface definitions and these face group functions would need to cull those points, and knots don't always exist in the middle of spans when those points get culled. But now I've got some homework reading the NURBS book referenced in the standard library since it seems to have all the b-spline hacks for reparameterization of spline stuff. I'm sure somewhere in there is the sauce I need for Edit Surface to work the way I want.
    edited July 16
    I put it all in a function and cleaned it up for external use; ApproximateFaceFunction(). It should auto fill with input examples.
  • kafka_wotepkafka_wotep Member Posts: 3 âś­
    Nice and useful. Thank you very much ;)
