Loft doesn´t connect
ben_dover177ben_dover177 Member Posts: 2
Hi guys, I´m making a dragon head headphones holder as my homework to school (cause apparently I do not like easy tasks), but I am having trouble connecting these 2 sketches with loft. Is it because these two scatches are connected at the end, because of the mirroring? I´ve tried all variations of the loft, but maybe I havent found the right one yet.
Also, how otherwise would you connect it? I tried sweep as well, but I do not know if it has any function that makes the sweep stop when it hits different platforms. Loft seemed like the most reasonable option.
Thank you for any ideas!
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 765 PRO
    When in doubt, take advantage of symmetry. I got this to work by modeling half of the desired loft as a surface, mirroring, then enclosing.
    https://cad.onshape.com/documents/7b265f9547ea96d0c8af0858/w/a086dde488156e48d7b16a86/e/f57d63f9362bd33c9acf3627
  • MichaelPascoeMichaelPascoe Member Posts: 2,586 PRO
    Try moving the profiles a very small distance apart so that they aren't touching. For more detailed help, please share a public link to your document.
