Not sure what I'm doing wrong - print in place box w hinged lid
Rank beginner here and while I've done many tutorials trying to get the hang of things, I'm not sure what I'm doing wrong with my attempt at a design that is intended to be "print-in-place"
Here is my design:
https://cad.onshape.com/documents/7b1918161eba86248c6b3614/w/8ae7620fe7389145b448b061/e/152d4d44295cbe329298507c?renderMode=0&uiState=68790af459dd0116c12e5ce2
I was inspired by this design, but its the wrong size/shape and lacks a few things that I wanted:
https://makerworld.com/en/models/781715-hinged-box-with-lid-print-in-place?from=search#profileId-718896
I can't seem to get the "print-in-place" aspect to actually work. My hinge lacks enough clearance or the right kind of clearance or maybe, clearance in the correct places?
Is the hinge design acceptable?
Any changes, suggestions, etc. - I'm open to alternatives.
I would appreciate any tips or feedback.
Thanks,
Trent
  • MichaelPascoeMichaelPascoe Member Posts: 2,673 PRO
    edited July 17 Answer ✓
    Looks like you forgot clearance here:
    Also, not sure you can print those rods while floating horizontally, you could try using cones instead; about 45 deg, this way both the inlet and the cone itself are supported during the print. That, or you could print the entire thing on its side and have the rods go all the way through.
