How to split IPT into multiple surfaces
matthew_leach
Member Posts: 4 ✭
I have imported an IPT file. Under the parts list, the entire thing shows up as body1. I can highlight different surfaces on the drawing, indicating that it is aware that the part is made of multiple surfaces. However, I don't know how to split this drawing so I can delete some of the unneeded surfaces. Whenever I try to delete, it deletes the entire thing because it is all one part.
My goal is to either delete the unneeded surfaces or to begin a new drawing with highlighted surfaces. Is there a way to do either of those?
peter_hall
Member Posts: 196 ✭✭✭
@matthew_leach You could split the part by creating a plane where you want to split. You can then delete the part you do not want. Alternatively draw a sketch on the part of the surface you want to delete and extrude to the depth of the part. Other more expierienced Onshapers may know of better methods.
5
In other way I think that your requirement is to delete particular surface of a part body and convert it as hollow surface similar as "Delete face" in Inventor. For this as a workaround you can apply shell on the given surfaces provided that complexity of part geometry should allow it.
When the OP says "I can highlight different surfaces on the drawing, indicating that it is aware that the part is made of multiple surfaces"
that suggests to me that when he talks about a "drawing" he actually means a model.
@matthew_leach
A good early habit is to think of creating a solid model in terms of "Modelling", rather than "Drawing"
It gets confusing for yourself (and others trying to advise you) if you don't make this distinction.
Until very recently, Drawings (a set of formal, symbolic 2D representations of the 3D model) were not possible in Onshape.
Drawing is a different activity, which occupies a different category on the forum, and it's one which not everyone will need.
Thanks!
