How to draw a puzzle type connection
alex_vestasalex_vestas Member Posts: 68
I created a plywood wheel 130 cm external Ø and 120 cm internal Ø, 10mm thickness.
https://cad.onshape.com/documents/24f4b79126f724f3850da688/w/716057b7e5240b984d31cb9d/e/ee7c1a9871fa0931e6dbfb30
I want split wheel into the 8 pieces and joint it use "puzzle"-type connection, like this:
How to create such type of connection? Also, how to add rigidity to an assembled wheel? The finished product should be a wheel with crossbars, like this:
  • MDesignMDesign Member Posts: 1,329 PRO
    create a sketch on the face of the wheel with the puzzle squiggly.
    split the wheel using the sketch.
    circular pattern the split.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 935 PRO
    Draw the puzzle shape and then use Split.
  • alex_vestasalex_vestas Member Posts: 68
    What tools should I use to draw the wavy curved lines of puzzle?
  • _anton_anton Member, Onshape Employees Posts: 525 image
    Sketch lines/arcs?
    Yep, sketch lines/arcs.
    https://learn.onshape.com/learn/course/fundamentals-sketching/
    curves that form the connection
    I should draw on existing Sketch 1, correct? There are 5 different types of arcs in Arc menu. Not sure which one is suitable for particular case. Or I should use ellipse?
  • Ste_WilsonSte_Wilson Member Posts: 575 EDU
    Have a play. See what works. You can always undo. Do the learning center courses linked above.
    edited July 2025
    I tried to draw curves use "Center point ark" and some other arks, but didn't succeed. In practice it is very difficult to draw these curves by hand, which also have to be symmetrical. I think this task could be somehow described by code and converted to FeatureScript.
