Failed Thicken from Loft Surface
finn_mckinleyfinn_mckinley Member Posts: 2
I am trying to create a spoon-like shape with a thickened loft surfaces however no matter what I try I cannot get the thicken to generate. I don't think there are any sharp corners or self intersecting surfaces but I can't work it out.
https://cad.onshape.com/documents/5893556cca3cd1839e55b0cc/v/e89ea03c098b70f5a9aeaa0b/e/9b49e041013ee2782134393bError
  • jelte_steur814jelte_steur814 Member Posts: 504 PRO
    edited July 18
    Document failed to load for version. Resource does not exist, or you do not have permission to access it.
    Did you make it public?
    can you thicken surface 1 or 2 separately?
  • MDesignMDesign Member Posts: 999 ✭✭✭
    0.5 mm is asking for too much considering the current curvature quality and small size of the original surfaces. Can you share the doc so that it can be copied for further inspection.
