Feature Request - Merging in Assemblies
Kate_BokowyKate_Bokowy Member Posts: 2 PRO
In an assembly I'd like there to be an option to merge all of the parts together. This will make it easier to export into other software that I use the general geomtery of it in. I would imagine it will create a part studio in my document with it merged and not change the actual assembly. I want it to be easier than manually making a derivative of all the parts in a studio and then doing boolean myself.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,604 PRO
    Create a part studio in context and use transform ⇒ copy in place to create a copy of all the parts. You can then Boolean or composite them before exporting.
  • S1monS1mon Member Posts: 4,061 PRO
    There are custom features out there that will Boolean All parametrically so you don't have to reselect each time the BOM changes. Unfortunately I can't find any at the moment.
    @GregBrown ?
    edited July 2025
    Autoboolean:
    https://cad.onshape.com/documents/8430fb350d753c30baca955d/v/5bc0f2a19e99306ee9eeb469/e/70b6ccbd425d478fbc478b5c
    Also has autocomposite in the same doc
