Surface Text
brett_laublebrett_lauble Member Posts: 3 EDU
Surface text feature works great BUT, it generates a slice cutout on the opposite side of the model. What am I doing wrong?
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 922 PRO
    Share your doc (make public and share a link), and someone will be happy to take a look.
  • brett_laublebrett_lauble Member Posts: 3 EDU
    https://cad.onshape.com/documents/a7f1c74a11145a04a278d758/w/f34104b45f858165f884c490/e/66e2301c8e3fa4fa541732f0
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 182 image
    @brett_lauble
    This has probably to do with the custom feature, should be an easy fix with the "delete face" feature.
    Yeah, seems like a glitch with the custom feature, but delete face definitely works.
    That worked, thank you.
