Persistent 401 Unauthorized Error with Python API Keys Despite All Checks
hari_haran541
Member Posts: 7 ✭
Hello everyone,
I'm trying to use the official onshape-client library for Python to connect to the Onshape API, but I'm stuck on a persistent 401 Unauthorized error. My goal is simply to authenticate and eventually create a document, but I cannot get past the initial connection step.
I've followed all the standard troubleshooting steps but the server continues to reject my credentials. I'm hoping someone might have an idea what I could be missing.
What I've Already Tried
- Set Correct Permissions: I have ensured the active keys have both Read and Write permissions enabled.
- Confirmed My Base URL: My account is on the standard free plan and my browser URL is exactly
https://cad.onshape.com. This is correctly set in my script. - Performed a "Clean" Copy/Paste: I've used the "Notepad Test" by pasting the keys into a plain text editor first before moving them to my script to ensure no hidden formatting characters are included.
- Synced My System Clock: I have forced a sync of my Windows clock with the internet time server to ensure there is no time-skew issue.
- Isolated the Problem: I am using a minimal test script (included below) that only attempts to authenticate and perform a single
GETrequest.
Test Script
This is the exact code I am running. It uses debug logging to show the raw request details. Even with this script, the authentication fails.
Python
import logging
import sys
from onshape_client.client import Client
from onshape_client.oas.exceptions import ApiException
API_KEY = "My_key"
API_SECRET = "My_key"
BASE_URL = "https://cad.onshape.com"
def check_connection_with_debug():
print("Attempting to connect with DEBUG LOGGING ENABLED...")
logging.basicConfig(stream=sys.stdout, level=logging.DEBUG)
client = Client(configuration={
"base_url": BASE_URL,
"api_key": API_KEY,
"api_secret": API_SECRET
try:
print("\n--- Performing test call to list documents ---")
# A simple, read-only call to test the connection
client.documents_api.get_documents(limit=1)
print("\n" + "="*40)
print("SUCCESS! Authentication is correct.")
print("="*40 + "\n")
except ApiException as e:
print(" FAILED! Authentication was rejected by the server.")
print(f"This was a {e.status} error. See the log above for details.")
if __name__ == '__main__':
if "PASTE_YOUR" in API_KEY or "PASTE_YOUR" in API_SECRET:
print("ERROR: You have not replaced the placeholder API keys in the script.")
else:
My Question
Even after all these steps, the script consistently fails with a 401 Unauthorized error.
Does anyone have any ideas for other things I could check? Is there any other system setting, account configuration, or network issue that could lead to a valid API key being rejected?
Any help or suggestion would be greatly appreciated. Thank you!
@hari_haran541 ,
I tried your code : https://colab.research.google.com/drive/1lJMjxsfkF8gS3nkcdzqLOqCNykB6puf1?usp=sharing and it works for me. Can you verify that you are entering the correct API Key & Secret? You can also validate your keys using glassworks, instructions here : https://onshape-public.github.io/docs/api-intro/explorer/#authenticate
