Team members can't delete objects in team?
andrew_greenberg693
Member Posts: 4 EDU
in General
Hi folks!
I'm the faculty advisor of a student aerospace team. I created a team under the Educational license, and I invite students to the team. None of the students can delete anything in the team, including objects they create themselves. This is supremely annoying. Is there a setting I missed after hours of searching?
1
It sounds like when you shared the document or folder that your team is working in you didn't give the team Delete permission. You can change this by going back into the Share dialog and editing the teams permission.
You can learn more about the different permissions and sharing here:https://cad.onshape.com/help/Content/sharedocuments.htm
I also messaged you if you need more support!
Unfortunately, it didn't help. If I go to the workspare or folder I want my student team to delete, I click on it, then Share, and then I click the pencil icon to edit the team permisions... and "Delete" is grayed out. I can't check it.
delete is grayed out, how do i assign it?
