Change Assembly / Part name via REST API
johannes_3000
Member Posts: 9 ✭
in General
Is it possible to change the name of an assembly via the /assemblies/d/{did}/w/{wid}/e/{eid}/modify endpoint?
Is there an endpoint like that for parts coming?
thanks!
Assembly metadata data (such as name) is updated with this endpoint:
https://cad.onshape.com/glassworks/explorer/#/Metadata/updateWVEMetadata
And you can use this reference guide:
https://onshape-public.github.io/docs/api-adv/metadata/#updating-metadata
Thanks, that should do it!
